Hi Leonard, so for example enabling that light that is currently turned off and then reducing all of their intensities down will give you this rendered result:
But these lights are really powerful for some reason, maybe because they are quite nearby your object or something like that. So you can't just adjust the Intensity slider to reduce them enough, you've got to turn the light colors themselves down from white to a darker gray color. Here were the light properties I used for the above rendering, note the "Color" parameter adjustement:
If you don't darken them they will be blasting everything with too much light making every single spot white.
