one small 'step' for man......
3142.2 In reply to 3142.1
Hi Danny - as far as I know I'm not doing anything special to set it up like that with the first created object having any special significance...
That may just be some behavior that NX6 decides to do when there is not any hierarchy set up or something.
What happens if you set the object name to have a kind of hierarchy in it like setting each object name like so:
Assembly:Cone
Assembly:Cube
Assembly:Cylinder
Assembly:Sphere
with that Assembly: appended to the front of the object name, does that change the import behavior at all and give you the hierarchy you want when imported into NX6?
