Find inflexion point?
3138.2 In reply to 3138.1
Hi Pilou, one method is to draw a line in the direction you want to find it in, and then use "Perp/perp" snap to find the closest or furthest point between the line and the curve, that looks like this:
See this previous thread for some more description:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3042.13
But there is also a BoundingBox command in v2 which you can assign to a keyboard shortcut, that will build a tight bounding rectangle around a curve and then you will have an intersection snap where the furthest point of the curve touches the bounding rectangle. That may be the easiest.
EDITED: 1 Dec 2009 by MICHAEL GIBSON
