Hi klaus,
> it would come in handy, if MoI had something like
> a 'transform-widget'
For MoI v2 one of the new features is an edit frame that goes around the outside of objects in the 2D views to allow for quick rotation and scaling, it looks like this:
It works similar to the edit widgets in 2D illustration programs.
You can also grab on the rotate widget at the top to do rotations, and if you click the rotate widget instead of drag on it you will get a wheel where you can adjust the center of rotation:
Probably in the future there will also be some kind of 3D manipulator for point tweaking in the 3D view but surface point tweaking is not really a fully finished area in MoI at this time.
