Looped edge selection
3112.32 In reply to 3112.29
Hi Keris,
> My only question is, does it work if you try to loop
> multiple faces at the same time?
Yeah, it looks through all loops in the entire model, anytime it finds a loop with 2 adjacent edges selected (or only 1 edge if the edge is not a joined edge between 2 surfaces) then all the edges in that loop get selected.
> Such as, in this model, you want to select the top and
> bottom edges, could you select the four edges needed
> to hint, press loop, and get those correct edges?
Yup, that works fine - that's why it only works if you have 2 adjacent edges on a loop selected and not just any 2 edges in it selected.
So for example if you select these edges:
Then when you run select loop it will make this result:
The loop shown here in red:
is not targeted because even though it has 2 edges in it selected, they are not adjacent to one another in the loop.
