sharp corner sweep?
3107.8 In reply to 3107.6
Hi niko, attached here is a setup for your window frame example that will work currently in MoI - select the profile, run Sweep and then select the 2 rails.
This will definitely be easier when you only have to use 1 rail, but the attached method is the way you can make it work in the current MoI release before the mitered corners for 1-rail sweep are ready.
