Instant hide
3092.2 In reply to 3092.1
Hi Danny, well most of MoI is set up with the idea that you select what you want before you run some command to modify things.
That kind of "Noun, Verb" ordering just tends to be the overall most common method with a wide variety of regular desktop software.
For example in a word processor you don't click on "Bold" first and then go select the text you want to make bold, you first select text and then click "Bold". MoI is set up in the same way with the regular hide function, it is intended that you select whatever you want to hide first, and then click on Edit/Hide to hide them.
I think it would be possible to make a custom command that works like you are asking though, I'll take a look. Maybe I can call it "WeirdBackwardsHide"... :)
