Pre-highlight?
3075.7 In reply to 3075.6
Hi Danny,
> How about a different color for the halo and
> highlight for breps when edge only?
I generally try to avoid using too many different colors for different things.
Often times I think it just leads to people wondering, "why is this stuff some weird other color" instead it actually conveying an easy to understand message.
Also using more colors makes things more likely to conflict with other colors that people want to use for their regular display, for organization or whatever.
> do you think after a Boolean operation that all faces should
> be showing for the new brep ?
Hmm, how about if it will follow the same wireframe state as the first selected object? That will make it consistent with other things as well, like the parent object name for example (if you have 2 different named objects and you boolean them, the new combined object gets the name from the object that was selected first).
