offset curve on surface
3072.2 In reply to 3072.1
Hi okapi, MoI does not have any special function to offset a curve on a surface.
But depending on what you want, it may be possible to create a tube around your curve using Sweep, and then intersect that tube with the surface using Construct / Curve / Isect to form a curve at the intersection.
Does that do what you need?
