HMAS Yarra II
3059.39 In reply to 3059.38
Hi Everyone,
Many thanks again for your kind responses :)
Colin, I downloaded that monitor calibration utility you linked to and applied it. Many thanks.
Jamie, I will be able to merge all of these parts in Simlab in the future. At the moment, Simlab doesn't use the object origins when importing and objects do not line up with each other. I have to manually drag them to where they need to be. The Simlab guys are pretty responsive though and will be adding an option to fix that in the next release.
David, you are very welcome and how is Aurora coming along? Have you found a way to get some on the water renders done?
These will be the last renders of Yarra for a while (until I can get it onto some "water"). These are straight out of Simlab with modded lighting to brighten things up a bit. Still not as good as Jamie's photoshopped version but I want to find a base render setting just for sending off snapshots.
Cheers All!
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
Size: 131.5 KB, Downloaded: 59 times, Dimensions: 1366x768px
Size: 161.7 KB, Downloaded: 57 times, Dimensions: 1366x768px
Size: 146.8 KB, Downloaded: 70 times, Dimensions: 1366x768px
