| Hi Mark,
 > is there a way to get it to cap just one end instead just both or neither,
 Nope, there's just a simple checkbox for the "Cap ends" option, so it's either both or neither for that one.
 > Once it's extruded without caps is there a way to then cap one end,
 Yep, you can select the edges along the end you want to cap, and then run Construct / Planar to build a planar surface through them, then use Edit / Join to join the new plane cap with the main body.
 > Once it's extruded with caps is there a way to remove one
 > of the caps?
 Yep, this is probably easiest - you just select the face you want to remove (by drilling down, that is when you click a second time on a solid) and hit Delete to remove it.
 > I there a way to change the display from ghosting to
 > wireframe and back on the fly? When ghosting, is there
 > a way to make the hidden lines show up better, be more visible?
 What do you mean by "Ghost" - do you mean hiding or locking objects?
 There is an option in moi.ini for adjusting the opacity of hidden lines, that is under:
 [Hidden lines]
 HiddenLineOpacity=34
 You can edit that to a value between 0 and 255, with 0 being totally transparent, and 255 being totally opaque.
 But that will change it for everything, not just in one circumstance.
