Hi Burr,
> Could that be a bug? It doesnt seem to be the same
> curve as if I delet the 2 top outer ones, then move the
> center one up to the point.???
Sorry, I'm not following this - it does not seem to be the same curve as what?
But remember, the Conic command also works by setting a "weight" value in addition to placing the points.
If you just drag the points around it is not changing the weight so you will not get the exact same result as the conic command is doing.
