Hi Burr,
> BTW: As I was fooling around with this, The Conic Curve in
> MoI, at an rho of less than .5, will produce a curve with 3
> points across the top.
Yeah, that will happen when you generate an ellipse segment that is longer than a certain size.
It's somewhat traditional to break up circles / arcs / ellipses of more than 90 degrees into chunks like that, for semi-arcane reasons.
You'll also find with those ones (Rho < 0.5) will have a center point snap for them way off to the side where the center of the ellipse actually is.
