Hi David, yup that is always a problem when people are totally dependent on things like "wizards" that build things automatically for them. If you get into a situation where the wizard/guided-steps type thing is not able to do something then they get hosed.
It does tend to be better to be able to do things manually but then also have a wizardy type thing optionally available to you so you can save time in situations that it does handle well.
> 2D works fine for me, as your going to get exactly what you lay out.
I guess the part that does not seem quite so good with that, is that it is not so easily tweakable by just changing a number parameter for instance. It would put some more burden on you to completely edit the 2D pattern (made of multiple objects) to adjust things.
> It's the end result that counts.
True, but if there is a way that gives you somewhat easier ways to experiment and tweak things really quickly then that can be helpful too...
