Hi David,
> Another approach would be arraying them (both
> prongs and gems) along a representative created
> uv surface and flowing everything back to the original
> surface as is currently done in Rhino.
I thought a bit about this, that maybe you would arrange things all along a line initially and then have the command take the spacing exactly from that 2D arrangement and try to place it along the curve.
But Jesse was describing originally about wanting to be able to control the spacing in between items as a parameter to the command so you could adjust it to different values.
