Export Script
3025.4 In reply to 3025.3
Hi Crusoe, I think I get the idea and scripting something along those lines should be possible.
Still need a few details to be cleared up though -
> I'd like to hit a button, "export all" (or maybe all visible)
Which one, everything or skip hidden objects?
> chose the filetype
This part is probably a bit difficult since there is not any kind of "filetype" picker set up, only things to get a full file name. So probably the script would have a fixed file type associated with it and you could edit the script to control the file type.
> and have it save each named group to a different file with
> the group name as part of the filename.
Into which folder would you want the files saved to?
Files don't normally just get created on the computer with a single simple isolated name, they need to go into a folder somewhere.
Or do you mean that the object names will include a full path with a folder name in it?
