something not good
3011.14 In reply to 3011.13
yes I know this effect I have already met with this several times I keep in my mind.
The MERGE command finally worked well thank you. Just I dont understand is this an separate command? because firstly I tried between the Boolean Merge and finally with the Shortcut method... that was fine.
