Hull Lofting Experiments and Issues
3002.7 In reply to 3002.5
Thanks guys.
I've attached a screen capture of the section I am attempting to loft. I've now tried it full hull length right round the stern using both loose and normal. It is really close using either option. It would be a really smooth hull! Also, a one piece surface would make trimming and then extruding the "plates" a doddle. The networked version created extrusions with internal surfaces that I had to hunt down and delete.
>My guess is that I won't be able to actually do anything about this
>stuff but with some examples it can help me to at least get some
>gears turning to maybe be able to improve it in the future.
And that's one of the great things about this software. Even if there is no way to achieve this I am impressed that you give consideration to ideas from your user base. Doesn't happen much in the software world.
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
Size: 15.6 KB, Downloaded: 111 times, Dimensions: 586x464px
