>>>>>>Added a script method so it is possible to set up shortcut keys that work the same as turning the mouse wheel for zooming in or out, including focusing the zoom on the mouse cursor's current location. To use them, set up the following on a shortcut key:
For zooming in, set up:
script: /* Zoom in a step */ var vp = moi.ui.getActiveViewport(); if ( vp != null ) vp.wheelZoom( true );
For zooming out, set up:
script: /* Zoom out a step */ var vp = moi.ui.getActiveViewport(); if ( vp != null ) vp.wheelZoom( false );
Do these have parameters that can control the "step" of the zoom. Like the "View Button Sensitivity". I would like to have my normal rate for the controls in the viewport and Mouse wheel, but then have the "ultra sensitive" on the shortcut.
Side Note: If those like me have there Trailing zeros set to a higher value, The little view zoom rotate dialogue display labels are not expanding properly and truncating the numbers.
