Hi Burr,
> The silouette command seems to not like "Sharp Edges" at
> this point. It will perform on smoothed silouettes.
Yeah the part that seems to be confusing people is that it does not attempt to duplicate edge curves that are also silhouettes.
That's because all edges of a solid are already being written to an AI file if you do a "SaveAs" to AI format.
So if the Silhouette command added in curves that were duplicates of existing edges, it would be pretty easy for someone to end up with duplicate stacked up curves in their AI file.
But it sounds like I should probably put in an option for whether to extract silhouette edge curves also or not, that should be pretty easy to do.
