How to bend the branches?
2981.18 In reply to 2981.16
right, it is much easier to get precise shapes out of moi.
But it seems you want to have some 'soft' control as to how the shapes are bent, and here modo seems more appropriate.
I like using both apps, depending on the specific task.
in modo, you should create your 2d shape first, making sure you have a god edge flow (use only quads),
after you give your shape some thickness you can either use
edge weights , or use minimal edge loop bevels or extrudes to get a hard shape.
