WIP - HMAS Sydney II
2980.4 In reply to 2980.3
Hi Mark, it's really looking great!
> Michael, would it be possible to include an option for these types
> of projected trims so that the shape of the drill determines the shape
> of the trim rather than it stretching along the shape of the target
> surface? The ones at the stern are going to bother me....
I'm not really sure if it is actually possible to do that exactly - for example if you have a planar curve like a circle, if you are trying to put that flat circle onto a curved surface it has to change somehow because you can only put a planar curve onto another plane without changing it in some way.
But it sounds like you may want to try angling the cutting objects so that the projection does not deviate so far from the surface normal.
When you do a projection, the curves are projected along the perpendicular to the cutting curve's plane, so if you rotate it for example in the top view, that will alter how it projects on to the surface.
