Problem with flipped surfaces
2970.2 In reply to 2970.1
yes there is a flip fonction in the folder Command but don't remember what this do :)
Sure you can try with a shortcut in writing just Flip in the second column ;)
Edit
Yes it's that : flip the object's normal (i suppose) by shortcut :)
But from your modele seems you must make that surface by surface :)
EDITED: 6 Oct 2009 by PILOU
