missed faces
2968.6 In reply to 2968.5
Hi andras, thanks for the example file, that helps a lot when I can repeat the problem over here.
It is a problem related to the tolerance value - segments that approached too close to that tolerance value could generate a bad extrusion with the small piece kind of collapsed down on itself.
It's fixed up for the next v2 beta, so this example and others like it should be working ok after the next beta release.
