WIP - WW1 Mark V Tank
2965.4 In reply to 2965.1
Hi Malcolm,
Your tank has turned out great!
> If you are interested I can extract the objects from the
> scene and send them as a separate file to you.
Yes, if you could send just those pertinent objects to me at moi@moi3d.com I would appreciate it.
There is one particular area right now where the surface/surface intersector has difficulty, which is when 2 tubular type shapes come together and exactly touch each other at 2 sort of "crown" points. This may be related to that problem. Until that gets fixed in the geometry library you may need to do something like shrink one of the shapes slightly to change how they intersect with one another.
