WIP - WW1 Mark V Tank
2965.1
Hi Guys.
Have been modelling a WW1 tank over the last few days - about 20 hours total modelling so far.
Thought I would show some screen prints of the current model and a quick render in Vue 7(see below). BTW, I haven't modelled a number of objects in the rear view to keep the rendering load down as they will not be visible in the render.
There are over 3000 objects in the scene and I would not have been able to manage them without the scene browser in Version 2. It does a great job of managing complex scenes!
I also found the "Hide background images" script to be invaluable.
Have had no problems with crashes while doing this model but did notice some strange behaviour related to boolean union of 3 objects on one occasion. Michael, I tried to boolean together a cylinder and two L shaped objects(as legs) and all the objects disappeared. I did an undo and redo but the same thing happened. I then tried a boolean of 1 leg plus the cylinder and it worked. I then tried to add the other leg but it wouldn't unite, and I was left with two separate objects. If you are interested I can extract the objects from the scene and send them as a separate file to you.
Malcolm
Size: 629.1 KB, Downloaded: 148 times, Dimensions: 1639x987px
Size: 592.5 KB, Downloaded: 135 times, Dimensions: 1691x987px
Size: 976.5 KB, Downloaded: 159 times, Dimensions: 1231x818px
