With the Align command you can draw a reference line the length of a dimension line found on the image using the line command. Then use align to match the ends of the dimension line on the image with image base point and image reference point to the end points of the reference line you drew with target base point and target reference point.
Hi Frenchy, looks like we are responding simultaneously.
