Start with V1 or V2 beta?
2954.4 In reply to 2954.1
Hi Paul, like Anis mentions above the video tutorials are probably the best starting point.
Watch them through a couple of times and then maybe see if you can follow along the steps to create each object.
That should give you a good overview on how to construct models.
> Would it be a good idea to go right to the V2 beta
> instead of trying to learn on V1?
I'd recommend going right to v2 really - you shouldn't have any problems following the v1 tutorials in the v2 beta, and there is quite a lot of stuff that helps out with basic things, like the new edit frame.
