Hi Paolo, thanks for reporting this problem.
> Wouldn't it be better to use only a decimal point as delimiter?
You can set things up that way if you want - MoI will use the decimal separator that is specified as your current preference in the regional settings for Windows.
If you want it to display a point instead of a comma, in Windows go to Control Panel > Regional and Language Options > Regional Options > Customize, and for the "Decimal symbol:" setting, put in a period there.
Once you have told Windows that you want to have numbers display with a point instead of a comma, MoI should also use that the next time you start it.
It looks like the problem in MoI is that you can only use a point as the decimal separator when entering an expression rather than a single number. I'll see if I can fix that up so that a comma will work in expressions when that is what is specified in your regional settings.
