Hi neo,
> But what is super cool is the way the can generate
> curve network from a 2d sketch...
Definitely the videos look very cool!
Have you had a chance to actually use the software though?
Or are you basing that statement just only from watching videos and not actually using the software?
I would say try not to make a big assumption on how things work based only off of watching a video.
For instance, do you know if the curves generated are guaranteed to touch one another and can actually be literally used to create a surface network?
Or does it tend to generate a whole bunch of curves that are disconnected from one another?
Even if that is the case, it certainly could still be very useful, but if you have not used the software you might not want to get too overly excited - don't just assume that it magically does everything you might imagine...
My main concern would be that you may probably get a bunch of curves that are only rough approximations and may not be suitable for direct use for surfacing, like pieces may not actually fit together, etc...
