I used the rotate widget in the V2 version. First I got the edge of the surface of the flower and translated it up a bit above the flower face. Then I moved each corner of the text block to meet that curve at its nearest point. Then I selected the text and moved the rotate widget to the touching point and then picked the raised edge and brought it down to meet the curve. Repeated for all text, then dropped it into the flower as deep as I wanted to go.
