Curve text
2920.34 In reply to 2920.33
Hi neo,
> Perhaps you could consider designing some like the rest
> of them (I really like your style)
Unfortunately doing icons is really quite finicky and time consuming work - I'm pretty happy when I get a chance to use some predefined ones.
So it's not likely that I will get a chance to do new ones for those anytime soon.
One thing that I did update though is how the icons are loaded for these special res:// cases .
In the next v2 beta, when there is a res:// icon it will first check to see if there is a PNG icon of that same name in the \ui\icons subfolder, and if it is it will load that file rather than get it from the built-in resources.
So that means in the next v2 beta you will be able to override those icons by just dropping new ones in \ui\icons and you do not need to alter the HTML.
For example to override the File icon which in the HTML is specified as res://FILEICON you can create a file at \ui\icon\FileIcon.png and it will use that one.
One note - the icon for Edit/Copy that was previously res://COPYICON has now been changed to res://COPYCLIPBOARDICON to avoid the collision with the existing CopyIcon.png which is the Transform/Copy icon.
So in the next v2 beta the icons that you can provide to override the resource ones are:
