Hi Al,
> the label refers to the field that you see in the image -
The image seems to be a screenshot of the lighting options dialog.
Is there a particular field within this dialog that you are asking about?
Maybe you could circle it or something to help clarify.
My previous message ( here) showed how to make a shortcut key that will set the fields on that lighting options dialog with a script.
Are you having a problem editing the script to put in your particular values?
Sorry it is still not clear to me what you are asking about.
> scale 1d, the demand is for having exactly an other way to
> scale entity being able to arrange the Pivot of the Frame
> for being able it to move or then to orient in various way-
Maybe you could show an example of what you are trying to do - Scale1D does allow you to arrange the origin point and orientation of the scale to whatever location you want.
