Short for lighting options
2907.2 In reply to 2907.1
Hi Al, yes it is possible to control all of the lighting options from a shortcut key script.
So you could set up some presets if you want.
The following script can be assigned as the command on a shortcut key to set a batch of lighting properties:
script: /* Set lighting options */ var v = moi.view; v.lightingStyle = 'Default'; v.specularHighlights = true; v.specularBrightness = 0.5; v.specularFocusSize = 0.5; v.metallicLighting = true; v.fixedLightPositions = false;
You can edit the various values in there to produce variations.
For lighting style, the value can be one of the following:
  'Default'
  'MoreFill'
  'LessFill'
  'KeyOnly'
  'CustomLevels'
  'Hemispheric'
  'Headlight'
Also when the lighting style is set to 'customLevels', there are some additional properties on moi.view that can be set: customKeyLightLevel and customFillLightLevel
Let me know if you have any difficulties setting that up.
