Is there a better way of doing this?
2906.4 In reply to 2906.1
Hi Abe, actually getting the proper cutting plane is not really that difficult, so the trimming method may be quicker overall than the other way.
The method for making the cutting plane goes like this - first draw a line with intersection snap from corner to corner:
Now select one of the neighboring line edges that touches it:
This forms a planar curve which can be extruded (you don't have to join first, extrude automatically joins pieces that touch one another), and the extrusion by default will go along the plane normal which is the orientation that you want:
Then you can delete the corner-to-corner line, and also the one face from the extrusion that you don't want to use.
That will produce a cutting plane at the proper orientation, you can select it and move it downwards maintaining the orientation by snapping on to the plane's own edge using the Transform / Move command like this:
Then grab a corner grip:
And scale it up so that it is nicely chopping cleanly through everything:
Then each of those pieces is cut by using the Trim command, with that plane as the cutting object.
Of course this will be much easier yet when it all happens automatically.
There will probably be cases when your shapes are not all in one plane where the mitering will not work, but here you have it all set up properly so that it matches up so I think this kind of non-planar situation should be feasible. (where it basically behaves like a planar situation in that local area).
