Simple raised panel but curved ~ Is there a better/simplier method than the path I took?
Started with curved long line added tangent straight lines extending the ends so the intersecting profiles will be the same size.
Made wire outline at the 45 degree intersection for each corner and used the two rail sweep.
Seems like a lot of work so any suggestions?
