Plane Problem
2884.14 In reply to 2884.13
I also struggled a bit with NURBS at the start. I had only just started to get the hang of polygons :-)
I try to think of NURBS more as a block that I am going to cut bits away from to make my final shape. I use other shapes to cut the block into whatever you want. I use booleans and extrudes more than planes.
For your building I would have started with a block then used another block to cut out the corner. This would have left me with a solid model.
Tony
(aka HamSoles)
