3DS problems
288.6 In reply to 288.4
288.4 In reply to 288.3
I just pulled down the files and tested it myself, no problems here. (3ds max 9 32 bit)
What happens if you scale up the model by 2000% and then zoom extent all again? Maybe it's a near-camera clipping thing...
I did that, no change. However, what I just found out is that pressing middle mouse button and drag (that is the pan command) makes the objects appear. After that, I changed the views from Wireframe to Smooth&Highlights and now the objects are visible.
Well, I still think there is a problem, I will do some more tests
