Hi Micha,
> Could be nice to get access to the npower mesher.
> Maybe you could add the quadmesher for advanced use.
> So, the user could try it for some projects.
No, I just do not think it is good enough to set up like that.
It would probably cause a lot of bug reports to be sent in without very much that I could do about them currently.
Also when I experimented with it, I only set things up to test on planar surfaces where big planar n-gons were generated. To make it work on curved surfaces as well would need additional work.
