New lighting model WIP
2801.42 In reply to 2801.39
Hi DesuDeus,
> Maybe before coding all this, having the code but not the
> UI part and using scripts?
Sometimes that can work, but not always.
Often times what is exposed to script is guided by what the UI needs to have available to it.
So it often helps to have a good script interface by also having a good UI design thought out at the same time that will make use of it.
It's also harder to do things like actually test the script interface without having a UI set up to exercise it.
