| Hi Danny,
 > How will "Fixed color" work , can we still change colours of
 > edges or surfaces if we want to, if we choose this option ?
 It's like vodkamartini mentioned above - you can still assign things to have different styles the same as before, it just alters the display only so that the display will show your fixed color choice rather than showing the style color as it normally does.
 Exports are not affected, so for example if you export to OBJ format styles will be used for the materials saved in the OBJ file same as currently.
 > Are the "Fixed color" edges of a Red cube still style red ?
 Yes, everything still maintains the same property values as before, it just purely overrides the display.
