Hi Burr, yup those numbers will be the same ones used by the script.
One of the nice things about how MoI's UI is set up is that the UI always talks to the core MoI code through the script interface. So that means that any numbers or things you see controlled by UI can also be controlled by a custom script as well.
> When you give one example script after its done, then we
> could just fill in the different numbers to create the
> different setups as scripts.
Yup, that should work pretty good.
