MoI on Acer Aspire One via VirtualBox?
2795.4 In reply to 2795.3
Hi Mark, also some more notes on this.
It looks like you may have to do some manual tweaking inside of VirtualBox to enable 3D hardware support:
http://www.virtualbox.org/manual/UserManual.html#guestadd-3d
quote:
Because 3D support is still experimental at this time, it is disabled by default and must be manually enabled in the VM settings (see the section called “General settings”).
So that is not very encouraging that it is labeled as "still experimental at this time"... but maybe you will be lucky...
You'll probably want to make sure you have the most recent release of VirtualBox to have the best chance.
