MoI on Acer Aspire One via VirtualBox?
2795.2 In reply to 2795.1
Hi Mark,
> The Aspire One uses Intel 945GSE chipset. Is that enough to run MoI?
Yup, although it is on the low end side of the spectrum, that is normally enough to run MoI although it is not really suitable for more complex projects.
However, I'm not quite sure what the case will be in a virtualized environment like you plan to use. It's possible that the virtualization will add some amount of additional overhead of its own, basically making that low-end card even less powered. But still that by itself is probably not the biggest problem.
> Is the 1024*600 display likely to cause any trouble?
Well, it's not a whole lot of room to work with for graphics-oriented applications in general, but MoI is actually able to run pretty well on that resolution. One cool feature of MoI is that the UI is scalable under Options / General / UI size.
The way the side pane UI hides different chunks of UI when you switch palettes keeps things going pretty well on these low res screens. I recently got a netbook as well, an Asus NJ-10 and it has that same resolution although with an nVidia graphics card in it, and I was able to run MoI well on it, although a larger screen is generally useful though.
Your biggest problem will probably be glitches in VirtualBox's Direct3D emulation layer - providing 3D hardware acceleration is I think a brand new function that came with the latest version of VirtualBox. In other virtual environments, the initial introduction of Direct3D emulation has tended to be pretty unstable and improved over some time. I would just not be surprised if this was the case with VirtualBox as well.
