Hi Brian
was going to post the same thing. There are overlapping non joined points in the 2nd profile. Also it would be easier if there were less points on the curves. If you loft set to loose it will give a smoother result. Do you need to follow the profile exactly? you can adjust the points after you have completed the loft to tweak the shape.
I just made half to make it simpler.
hope it helps jamie
