[Request] Rect from center advanced
2783.16 In reply to 2783.1
Hi DesuDeus,
> I like the Rect from center tool, its very cool but it lack something.
> You should have two snap points, the corner + the edge close to it.
> For example draw a circle that's not align on any grid, then try to
> draw the bounding box... yeah its impossible !
> You can do it with a mix of tools (lines) of course but its not very fast.
As Pilou and Paul mentioned, it is actually not impossible at all! Just use construction lines to get your circle framed, it only takes a couple of seconds.
Maybe it is not clear that a Construction line is actually a special helper object in MoI and not the same as just drawing in additional regular line objects that you then have to erase.
Construction lines are special helpers that you can create any time you are drawing, by holding down the mouse and dragging on a point instead of clicking on the point.
So for example in your case you describe here about drawing a box around a circle not grid aligned, that looks like this:
So as you can see there, definitely not impossible! :)
And that can be done quickly too, just a couple of seconds as you can see.
Note that you do not have to exit the command to create construction lines - when I'm talking about "construction lines" I don't mean drawing additional regular line objects in the scene, I mean using the special quick construction line helper tool that you can do by dragging instead of clicking on points.
