Hi nukkle, I would like to do this in the future to make the UI more able to be re-arranged and docked to different monitors. But unfortunately it will take quite a large amount of work to make that happen so it will probably be quite a while before it will get done.
In MoI version 2, there is an option for switching the side pane tools to the left side of the screen, under Options / General / Side pane position. If you set that, then you could stretch MoI's window to span both monitors and have the tools on the left side one. That may get you close to what you want currently.
