Hi Pitrak,
> 1. Will rebuild curves (planes?) be part of the 2.0 release?
No, but I do want to add it in at some point, probably in v3 when I have a better spot to put a list of additional functions in the UI.
> 2. Would it be possible to have offset rebuilding curves as
> standard behaviour? So if you offset a curve with 5 control
> points, you get one with 5 control points as well - at the
> corresponding locations? Maybe with a "auto, exact, ..." option?
It's generally not possible to produce an actual offset curve by only using the same number of points except in special cases.
Offsetting changes the shape and proportions of a curve, it is not really like other transforms such as moving or rotating. Because of that the offset curve is generated by a kind of fitting process and not just by transforming control points.
I do want to try some things to reduce the complexity of offset curves in the future though.
