obj export problem
2766.1
Hi, I created a cube and sphere solid and did a Boolean difference then exported as an obj, output N-gons. When I import the obj into 3ds max the obj is messed up (the same is true when I open in UVMapper). One of the attached images shows the imported obj in max the other shows the obj in MOI along with the export settings.
