...my modest proposal
13. Blend curves (G1, G2, G3?): The Construct|Blend command should be finished so we could make blending both curves and surface edges. I think that the intended AI export makes no sense without it.
14. Loft: It might be a good idea to add an option for the loft command in order that the closed surface could be created.
15. The helix, spiral, etc.: To add the command for making this curves.
777. Unfolding: Unfolds a developable (poly)surfaces to a planar (poly)surface, optionally with connectors like in formZ. You can make a physical cardboard model, then! Utopia, isn't it? hehe..
Petr
